The Makita TM3010C is a corded oscillating multi-tool with a 3.0 AMP motor, designed for various applications such as cutting, sanding, and scraping. It features a variable speed control dial, soft start, and a clamp system with 12 tightening settings, available in TM3010CX1 (new) and TM3010CR (refurbished) models.
Tool shut itself off during moderate use
Why did my tool shut off during moderate use, and won’t turn back on?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Check to see if the brushes are ok. Possibly a reset button? Using a multimeter check the switch works. Also with it plugged in and the machine switch in the on position, wiggle the wire up and down in various places. If the motor starts you have a broken supply cord.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Ted4 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 51
