The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
797вопросов Показать все
when turning device, letters will not rotate with it.
I can only read my Kindle Fire in the short stubby side.
will not allow me read in any other position. I have allowed the battery to go totally dead before recharging, thinking this might solve problem. But alas It didn't help.
It's frozen in one position. How do I clear this up. It is only 2mo.old.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
marlene johnson, try to tap on the Settings icon (looks like a gear) in the top right corner of the screen. You should see where you can lock and unlock the screen position. More on that on here, hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 5
6 Комментариев:
Thanks! This helped me too.
из
you are welcome:)
из
Thank you. This was the answer to my problem.
из
you are welcome ;-)
из
Thank you ,You help me fix my kindle ;)
из
Показать 1 больше комментариев
Добавьте свой ответ
marlene johnson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 1,292
