Repair guides, disassembly, and troubleshooting information for the Nintendo Switch 2, the successor to the original (2017-2021) Nintendo Switch consoles. Announced January 2025, and officially released on June 5th, 2025.
Can the fan be replaced without removing the heatsink?
Looking at the disassembly videos it looks like maybe the fan could have enough wiggle room to be removed without removing the heatsink. Can anyone confirm if this is the case?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi Tom!
Yes you probably can take it out without removing the heat sink, BUT...
  • It's slightly stuck to the heat sink with tape
  • You can bend the heat sink if not carefull
  • It's difficult to take the fan it's ribbon cable out (as a part of the heat sink blocks it).
So, it's recommended to remove the heat sink first. You can remove the fan, but you need to "pry" a little to take it out.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Tom Harrison буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 128
