Xiaomi Poco X3 Pro - это смартфон бюджетного сегмента от Xiaomi, выпущенный в марте 2021 года. Он оснащен 6,67-дюймовым IPS ЖК-экраном, основной камерой на 48 Мп и процессором Qualcomm Snapdragon 860.
Phone doesn't turn on
Deadboot phone it doesn't turn on, it automatically turned off it's power and it does not indicate charging or response.
Это хороший вопрос?
Счет 0
1 Комментарий:
Hi @jamesmarsh12177
Does the phone indicate that the battery is charging when a known working, compatible charger/charger cable is connected to the phone?
Has the phone been dropped or gotten wet at all?
из
Добавить комментарий
1 ответ
@jamesmarsh12177 first check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure the connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger.
Commonly a No Power situation is related to either the charging board, a shorted battery or a torn flex that comes from the daughter board to the main circuit board. Check/replace those. Then check the voltage on your battery connector with the phone plugged in and without.
To replace the battery, use this guide Poco X3 Pro Battery Replacement For the rest use this video Let us know what you find out.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
James Marshal Jaurigue Belonio буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 16
За всё время: 188
