What component to repair on flash PCB?
In flash mode, flash won't fire.
That means flash PCB can have problem or ?
Issue can be to disassemble flash PCB unit.
Problem is : where to use multimeter, what component to change and where top buy it...
Это хороший вопрос?
2 Комментариев
Flash's PCB problem maybe occured when i hit the camera on my leg..
I was trying to fix an message error "turn on, turn off" due to dust on the lens inside switch, because i did not want to dissassemble it to clean. I read this method on the internet, it helped but maybe i hit too hard!
из Allainguillaume
The only way to see what is going on after "getting slapped" to hard' is by opening it up and take a look at the flash unit.
из oldturkey03
