Top loader washer Model number MVWB835DW
Won’t turn on
Novice DIY here. Have a Bravos XL that seemed to have stopped mid wash. Read up on some things. Power supply is blinking green. Control panel has no power. Tried cleaning where I could see corrosion. Order a panel ?? Fuse ?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi Vince,
I haven't had a chance to look into this in any depth for you, but I did locate the tech sheet for your washer. This has service information including wiring diagrams and troubleshooting steps that will be a must see to try and diagnose the issue. Here's a link to the PDF file.
techsheet-w10607408-revf.pdf
I've also gone ahead and uploaded it to the device page so it will be available as long as iFixit is around.
Techsheet W10607408 Revf - iFixit
Update (07/01/25)
As I mentioned, the tech sheet has you covered. Here's the part you're interested in.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
Appreciate it. I’ll try to make heads or tails of it. I believe my problem is off J18 going to the user interface board to the controls. Not sure if I got a voltmeter. Stay tuned
из
Same issue. Here is mine. I watched this video. https://youtu.be/IpLF007BXmw?si=HrbwqCuu...
Of my four rectangular parts on the circuit board only the top one is dark and slightly corroded so I’m trying to clean it. I was having the same issue of it stopping mid cycle.
из
Добавьте свой ответ
Vince буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 113
