Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
Why are the R1 and R2 buttons not responding?
I bought a few brand new PS3 controllers from Amazon. Two came in a pack and one works fine. The other one works fine except for the R1 and R2 buttons. The buttons aren't broken, and when I took it apart, I tried using the sensors to push the buttons and it didn't work. I did the same for the L triggers and it did work, so I know it's supposed to work. All the connections and ribbons look fine, and it's brand new, so it's clean inside. The sensor pads and everything look fine, too. I don't know what else to do. Any advice?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi!
I would return it for warranty and get yourself a new one. If they are brand new, they should replace the controller!
Most likely caused by the circuit button membrane. Replacing this could solve it! But again, just get yourself a new one with warranty!
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
That's what I was planning to do if I couldn't fix it myself. If it requires replacing something then I'm just going to try to return it. Thanks!
из
My pleasure! Yes, the button membrane circuit need to be replaced to get it working. Have a nice day!!
из
Добавьте свой ответ
Charity Senger буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 41
За всё время: 229
