Why is my Despenser not making cold water cold
Это хороший вопрос?
Это хороший вопрос?
There are a few things the simplest is the cooler plugged in into a working outlet?
Then is the compressor running, you should hear a hum. Next, the compressor uses a gas which when compressed gives off its heat and then when as a liquid allowed to gasify again becomes cold, if the gas has leaked out there is no way to make the water cold.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 33
