Released on June 23, 1996, Model NUS-001, 64-bit gaming console
Nintendo 64 issues including briefly showing no controller message
Picked up a Nintendo 64 console at a yard sale this past week. Noticed a few issues I am not all that familiar with. One is the no controller message. If the console has been turned off for awhile, then I turn it on, it will show no controller, but then within like 10 seconds the message goes away and the controller works just fine. Does the same thing with 2 different controllers. I did open the console up and looked at the solder points on the first controller connections to see any cold joints. They seem ok to the naked eye. Should I just try a reflow just in case?
Another issue is, I think there is something wrong with the shell. Game cartridges have a very tight fit going into the slot. Even if I took off the plastic piece inside and the 2 opening doors and just had the opening for the cartridge, it goes in super tight. You have to even pull the cartridge out with a lot of force. The console is a US model and the games are US games, so I know it's not a Japan thing.
Could it be the plastic might have warped? It looks normal. I never came across an issue like this. Another issue is the power button, sometimes when turning it off, the power stays on. I have to slide the power button up then back down to get it to finally turn off. Doesn't happen all the time. I took the console apart and took the button out and cleaned it and cleaned the console part where the button slides into. I also cleaned around the button itself. Still, same issue. Not constant, it randomly does this. Never seen issues like this with a N64.
Even the memory pack cover does not fit properly. It wont clip in and stay attached to the console. I had a spare one from another console and that too has the same issue. Very weird. It is just a basic N64 console. I dont see any mods or anything like that.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi there!
First, you can try to re-solder the solder joints regarding the controller ports and see if that works. Does the same thing happen with the other controller ports as well?
2nd thing, looks like someone did a re-shell for the Nintendo 64, explaining why the games goes in very tight. I think a new (original) shell will fit it, together with the memory pack cover that does not fit well.
3rd, how is the power button? Still looking good? You can solder a new one in and see if that will do the job!
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Its a legit original NES shell. It has the Nintendo symbol on it, its the charcoal black version. I think it was warped. With the power button, I am starting to believe it is part of the shell issue because if I take the shell off and just turn the power switch on and off, it works just fine each time. I think 99% of the issues I mentioned is because something is wrong with this shell. And I double checked, its an OEM official Nintendo N64 shell.
из
Yeah sounds like it! I would look for a OEM official Nintendo 64 top cover and replace it completely. This will fix a lot of the issues you are having. Those are not easy to find.. But it's worth a try (maybe a broken/donor N64 will do the trick).
из
Добавьте свой ответ
Sillychaoss2988 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 19
За всё время: 79
