stop lights not working
I have no stop lights check break light switch good it's blowing fuses
Это хороший вопрос?
Это хороший вопрос?
@stevepucke73877 if it blows the fuses when you apply the brakes you have a short circuit. This will be either along the wiring harness or in the bulb socket. You will have to check by using a multimeter in ohm mode. If you are unfamiliar with this check something like this video and I would start on the light socket itself.
Here is the wiring diagram for the '99 S10 but it should work for the Xtreme as well
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 38
