Soldering is a method of connecting two pieces of metal together by melting another filler metal in between them. There are many kinds of soldering, but this article is designed to teach you the basics of electrical soldering.
Trying to solder, leaving goo instead of solder
I've never been great at soldering and I've been trying to improve while fixing some of my devices. Right now I'm trying to fix an issue with my Nintendo DS USB-C modded charging port. The solder has been loose and my DS won't always charge unless the cable is in a certain position. I'm trying to solder one of the points to keep it more secure, but it's not leaving solder there, it's just this gooey flux-like stuff. I'm using flux to make sure it sticks, I'm not sure if I'm using too much. I'm using a Weller soldering iron with 60/40 rosin core solder, and rosin flux paste. I've attached pictures of what the soldering job looks like. Any help is appreciated.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
6-pin USB C is recommended to solder using hot air fan if possible. You have to pre-solder the connector pins from bottom, clean the motherboard using wick (goot wick), add flux to the connector pins. Pre-heat the board using hot air fan and then apply a socket. gently pushing it from the top. Hot air fan should blow from the bottom to avoid socket damaging.
There also another methods, like using soldering paste etc.
Of course, you can do it using iron, but you have to take very thin copper tip and good, well heated soldering station.
Things like on your photo always happens with a beginner. Plastic near the socket is melting. It's impossible to solder it, plastic will ruin the solder because it contains carbon trash and acids.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
MikeyLORR буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 49
