Identified by model number: JBLLIVE660NC. It is a wireless over ear headphone that was released in 2021. The JBL Live 660NC is a Bluetooth 5.0 capable headphone featuring Adaptive Noise Cancelling technology, JBL Signature Sound, and up to 50 hours of battery life.
Device fell down, not starting again
Yeah pretty much what the Title says, i wanted to know if anyone has any product specs for the screws because i cant get it open to fix it :/. I already asked multiple repair shops near me if they could fix them, but they all said they dont fix JBL headsets, so i decided ill do it myself but i dont have the fitting screwdrivers. Thanks in advance
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
@igoorvank not quite sure if you are referring to the triangular shaped screw heads. I can tell you that my iFixit Manta driver kit does have bits for that in the kit. You could try one of these Tri-Point Screwdrivers
Now, you can also ty a small flathead screwdriver to loosen those screws. Something no larger than 1.4mm will work. Just make sure it is fully inserted so you do not chew up the screwhead.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Yeah i got these Triangle like screws but my set doesnt have the right size ill just buy a set with more of these bits. Thank you for the answer :)
из
Добавьте свой ответ
Igoor VanK буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 35
