My Ender 3 Max Neo Stops Extruding Filament Mid-Print
While you may be confused why I'm putting this under Ender V2 Neo, they are functionally the same device, size being the difference. Now, here's my issue, when I print the print will start off fine enough, but filament will consistently stop at about the same point each time. https://preview.redd.it/continuous-print...
More or less what happens is that the print starts off normal, and then the print simply stops at a certain point. This isn't because the filament is caught on anything, I've had this issue for a few months and taken apart a few items of the printer. I'm not sure if this is a settings issue, or if this might be an issue with the hotend, as I had to replace it, and these problems started after a few such changes.
If you have any questions you need me to clarify, I'd really like to solve this. Thanks.
Это хороший вопрос?
