Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
iMac 27” mid 2011 EMC2429 won’t turn on
I got an Imac 27” mid 2011 EMC2429 which was not turning on. No chime, no fan working, Nothung.
First I thought it is PSU. I tried my PSU on another Imac it works fine. On my Imac I tried another working PSU same result not turning on.
Then I have noticed that when I plug it in, Led 1 on motherboard blinks for a second. Anybody could help me what can be broken, How to fix it?
Это хороший вопрос?
Счет 0
2 Комментариев:
Did you take the logic board out and refreshed the thermal paste on the CPU?
из
Yes, it is completely fresh
из
Добавить комментарий
1 ответ
Then I’m suspecting you didn’t seat the CPU chip cleanly into the socket, often the pins get bent. This system is hard to mount the heat sink springs and the chip.
You’ll need to pull the CPU out and check the socket pins. Be careful as bending them back can snap them. You’ll want to soften the spring a bit.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Tural Huseynov буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 20
За всё время: 141
