How to reassemble wii eject system
I meed help to reassemble the wii plastic and metal levers that push in and out the disc
Это хороший вопрос?
Это хороший вопрос?
Hi!
It’s for the best to see the (1st) reference picture here: https://www.ebay.com/itm/266243035264
Please let me know if you have any questions!
Был ли этот ответ полезен?
Thanks it helped a lot i finally could buid back the pice together but now i need to know how to put it in back in the metal shell
When all the plastic is installed (as in your photo, that piece need to point towards the bottom) turn the top part over and installed it carefully. I think you just need to put it on and fasten it with the screws. This should do the job!
The drive need to look like this: https://collectedgaming.com/products/nin... (see reference photo).
I put the plastic piece all toghter but dosent work like it was... the long arm dosent stay in track and the one between the aluminum and the long one gets stuck (it can only move when i move the aluminum one)
https://www.reddit.com/r/wii/s/kUl6cU2TM... i have some photos here tryna find some help
I know the part you mean now! This one is difficult to place back if it got loose. You need to lock it near the gears. At this point I would just buy a new drive to get it done. You already assembled the top part, but the long metal arm in the middle is not part of that one unfortunately...
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 46
