6.1 megapixels, ISO 200-1600, DX format, 1.5x field of view crop
42вопросов Показать все
How do I repair the top LCD?
The top LCD is fading where the remaining shots are displayed. Also, a few of the flash modes don't display. I've barely used the camera (4,700 actuations since 2004). I tried looking through the guides but the closest one seems to be removing the top cover. Is that the guide I should follow? Does anyone have any advice regarding the correct part number? Or could this be resolved by reseating the LCD and/or ribbon cable?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Michael Braun, it looks like you should get to it with the top cover removed. It appears that it is attached with 2 screws and soldered to the PCB. The external LCD FPC unit part number is 1C998-628. Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Michael Braun будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 957
