First generation, based on the Ford C1 global platform.
Hazard lights turn on and off randomly
The hazard light keep turning on and off randomly
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
First thing to do is try to pin down where the problem is coming from. Since the only part you can really get to is the switch itself, I'd try disconnecting the switch to see if the problem goes away. You can also follow the service manual test procedure for the switch to see if it's working correctly.
Mazda 3 Service Manual - Hazard Warning Switch Inspection - Exterior
Try those suggestions then come on back and let us know what you found. Good or bad, your experience could help the next person who comes along with the same problem.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Patrick Thomas буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 25
