Engine overhaul and CV axle wirk
Hw to work engine overhaul and CV joint of Land cruise
Это хороший вопрос?
Счет 0
2 Комментариев:
@emma5484 what exact year and what exact engine is your land cruiser? Are you referring to a complete engine overhaul? Have you done one of those before?
из
@emma5484 what exact year and what exact engine is your land cruiser? Are you referring to a complete engine overhaul? Have you done one of those before? This is one of the cases where you really need to be more descriptive. If you want to do a complete overhaul of your engine, you need to tell us that and need to have a bit of experience with that too. For now you can use the J100 Engine Mechanical to work on the engine and for the driveshaft (CV axle) use this chapter J100 Suspension & Axle
из
Добавить комментарий
1 ответ
Emma,
That falls well beyond the "tell you how" and well into the DOWNLOAD the service manual area. so click that blue link to download the 'Toyota-Landcruiser-J100-1998-2007-workshop-manual' which gives you everything you need to do your chosen tasks except the tools and the skills which hopefully YOU can supply. (the zip file can be opened using win-zip, 7zip win-rar and so on or similar programs on MAC or LINUX; all are available for free, but your computer is probably already set-up to decompress it) The file contains a bunch of individual PDF files readable using free readers on pretty much any device. if it ISN'T the one you need, you are in luck, because unlike many other manufacturers, your manuals are easy to find on-line... search for the one you need.
Good Luck
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Emma буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 3
За последние 30 дней: 30
За всё время: 216
