APS-C mirrorless digital camera announced in February 2014. The Alpha 6000 can take pictures up to 24.3MP, and video at 1080p60. Also known as the Sony α6000.
Screw head stripped, need ideas to fix
Hello community,
I have a challenge, the screw head of the frame has unfortunately stripped. I have tried the rubber band and glue trick with no luck. I ideally would like to be able to remove this screw without breaking the frame. I do have a spare frame in the worse case
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
@anthonychc that is a tough one. You either need to drill it out or use something like a Dremel grinder to remove the screwhead. Should you decide to drill it out, you will need to use a drill that is slightly bigger than the thread. All you want to do, is drill it big enough that you remove just the screwhead. That will allow you to remove the thread later on with something like a pair of needle nose or similar pliers. Those scows are M1.7 thread. That means that a 2mm-2.5mm drill bit should accomplish this.
iFixit does not sell the frame. You would need to rely on an internet search for part number X-2589-185-1 to locate one.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Anthony Chc буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 16
За всё время: 16
