In 2012, Sony Entertainment announced that the company would be releasing a new version of its 2006 Playstation 3 console. The new console is called the Playstation 3 Super Slim and is identified by the model number, CECH-4000. The PlayStation 3 Super Slim (CECH400x) is the third version of the PS3 video game console produced by Sony Computer Entertainment. It was released October 25, 2012.
Why is my PS3 super slim not powering on (no light)
Hello!
Today i have a ps3 super slim that, when plugged in, does not turn on or show any lights when plugged in.
I had recently played games on this and had no issues, but noticed the console was getting hot without playing anything.
So I opened it to clean all of the dust out and replace thermal paste. After putting it back together, it started to show signs similar to power supply failure: pressing power button would turn on the console for a few seconds and then power off. Eventually it stopped powering on at all and no longer shows a red light when plugged in.
I have since tried other power outlets, a different power cord, and replaced the power supply. No change in symptoms either. Any other options??
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi!
Most likely something on the motherboard died. You might want to run some tests and check for damage or replace the motherboard.
Replacing the motherboard is expensive, but will solve it..
Был ли этот ответ полезен?
Счет 2
5 Комментариев:
Hello, I was wondering if you had any further insight. Do you know of any resources I can use to test the motherboard?
из
Also, if I purchase another motherboard of the same model, is it a simple replacement? No marrying of optical drive I mean
из
Hi!
You can use a multimeter and test some components on it. To be honest, I'm not sure which components... But it could also be related to the APU... Which is possible at this point.
Replacing the motherboard does require to transfer the PCB (daughter board from the optical drive). But the PS3 Super Slim doesn't have a PCB attached to the drive, so a motherboard replacement is all that is needed.
из
Thank you so much for all this info!! I truly appreciate it. I cannot wait to get back to my cd's, dvd's, and games with this old thing. Have a great week.
из
My pleasure! Please let us know how it goes! Have a great week as well! Take care!
из
Добавьте свой ответ
Christian B буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 34
За всё время: 34
