PS5 Disc -> Digital BIOS SU-101217-2 Error Code
My PS5 originally wouldn’t go into Safe Mode and only showed a blinking blue light. I suspected the disc drive, so I swapped in a known-good one while keeping the original daughterboard, but updates still failed. I then pulled the BIOS chip, read it, converted it to a Digital Edition BIOS, and flashed it back. After that, the system would go into Safe Mode, but it stopped detecting Wi-Fi networks. I repeated the process and even tried another BIOS chip from a disc console converted to digital, but nothing changed.
The update fails instantly with error SU-101217-2. Online, I’ve seen guesses ranging from SSD issues to a bad Wi-Fi IC to the southbridge needing a reball. Since the southbridge is right next to the BIOS chip, I wondered if I might have affected it during the work. Under a microscope I didn’t see obvious damage, but I tried a reflow anyway since I don’t have reballing experience. After the reflow, the console didn’t automatically enter Safe Mode (could just be because I had reset the database beforehand), but the symptoms stayed the same: no Wi-Fi networks at all, LAN works fine, Bluetooth works, and updates still fail instantly.
I tried restoring the original BIOS, but I lost the small 4.7k resistor under the BIOS chip during rework, so I couldn’t test the original firmware. At this point Safe Mode only works when selected, Wi-Fi is completely dead, LAN and Bluetooth work, and the system still throws SU-101217-2 immediately. If anyone has run into this exact combo or has advice on what to check next, I’d appreciate it.
Это хороший вопрос?
