Model Number: wa50k8600av/a2 Stainless steel 5.0 cu. ft. top loading washing machine
Why is my washer making a strange noise
My washer makes a strange grinding noise when I power on and it won't work
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
  • Make sure the washing machine is set on a level floor. If the floor is not level, use the levelling feet to adjust the washing machine.
  • Make sure the washing machine is not contacting any other object.
  • Make sure the laundry load is balanced.
  • Make sure the laundry is spread evenly in the washing machine. Spread out the laundry evenly and start again.
  • Make sure the space around the washing machine is free of objects.
  • Humming is produced normally during operation.
  • Objects such as coins can cause noise. Remove these objects from the washing machine after washing is complete.
https://manualsfile.com/product/k20zieg3...
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Chardley буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 24
За последние 30 дней: 24
За всё время: 24
