inside Mini 4 pro GPS module
Hi,
I was inquisitive to see which GPS module DJI used for this model, so I removed the shield. This disturbed a few components, as can be seen in the image, and didn't show the GPS chip.
Does any one know which way round the component bottom right should be or what it is?
I hope you find it interesting, but I suspect it may never work again.
P.S. I looked closer at the component, but it's not clear. Here's what I think it says on it: ASAXAF K61444T
P.P.S. When I removed the GPS shield, I used a pin in the small hole, which slid some components off.
I've just found that the shield is magnetic, so I could have used a magnet.
NOTE: BEWARE OF MAGNETIC COMPONENTS BEING ALSO LIFTED!
C
Это хороший вопрос?
Счет 0
2 Комментариев:
Is the image there now?
из
Добавить комментарий
