How to take apart and repair the Panasonic Lumix DMC-FX01.
12вопросов Показать все
Black point when take picture
Hi all,
My Panasonic Lumix is an excellent material for what i do. no need of extra things. It suits me perfectly.
But, actually it give me some bad results.
For any know reason, some picture i take have a black point on it. the black point seems to appear in some particular situation, like a little zoom or with a more longuer autofocus time.
This give to me some pictures with a black point.
Do you know from which part of the material could be in cause ?
Is it Lens ?
Thanks in advance for any answer you can give me to help.
Best Regards.
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Julien, both of your questions point to a bad or dirty lens. You can try to clean the lens or to replace the lens assembly. Of course you also want to make sure that your flex cables are properly seated, and free of any corrosion. Here is the guide for the lens replacement. Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
Julien будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 713
