Broken display casing and hinges. How to swap with replacement parts
Hi all.
I dont fully know how to describe this. Basically my macbook fell of my bed and the screen half has broken off from the bottom, component/hardwear part off my mac.
The screen works and is hanging by a thread to the bottom half. I have to jostle it around untill it displays.
I have bought a faulty macbook with what i guess is a faulty logic board. the aesthetics/ casing are all perfect however
It switches on but doesnt recognise drive and doesnt charge.
To put it simply i have two 1/2 working macbooks.
Out of changing the power supply and logic board from the hardware working one, or transferring the screen half from one to the other.
Which is the easiet and is their a guide for it?
Thanks in advance people =)
much appreciated.
Это хороший вопрос?
Оценка 0
3 Комментариев
Please give us the last three figures of both serial numbers and we can get you to the correct guide.
из
I dont havee serial for either as both top cases have been removed. And the spares repairs macbook came without a battery.
The screen damage macbook is late 2007 and the logic board failure is 2006
из
Check if the two heatsinks have the same form factory. Also check if the inverter and fans connectors look the same.
из
Добавить комментарий
1 ответ
Выбранное решение
Just swap the logic board from a machine to the other one if the two boards are compatibles.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
tom будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 463
