Nokia E90 is a 3G smartphone made by Nokia and the latest model of the Communicator series.
6вопросов Показать все
Can I get a board connector
while removing the strip from the board .. i broke one of the connector which connects the strip to the board ... how can i fix it .... or i have to place a new connector ..
and where can i get a connector too.. :-(
my model is nokia e90
there are two similar connectors at the side of the logic board .. near the camera ... i think it comes from the display ..
Это хороший вопрос?
Оценка 1
7 Комментариев
There are a few connectors on the logic board? Which one did you break?
из
из
i have uploaded a image of it ..
из
Where did you place the images :)?
из
now i have placed it ... can u see it :-)
из
Показать 2 больше комментариев
Добавить комментарий
1 ответ
Выбранное решение
chaman, that is a Coax connector. Listed as X4500 in the schematic. The Nokia part number is 5429117 N-SERIES CONN COAX 30POL F VERTICAL 50V 0.3A P0.4 It is also used in the N93i. Of course, it is solder on the logic board and will require some pretty good soldering skills. The only places I could find are in Europe, one being in Finland. You may want to do a Google search. Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
ya but its very difficult to find it in india ,, i am not going to do the soldering thing .. it would be done by the my mobile repairer .. and i dont know how to get the connector ...
из
chamann, there is one here and another one here and here is one from Finland. All you have to do is go online and purchase one and I am not sure how I can help you with that. I can't seem to find one in India, but you may have better luck.
из
Добавьте свой ответ
chaman будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 1,516
