The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60вопросов Показать все
Glass is broken but the screen and touch are working fine
The gorilla glass on my phone is broken
not screen just the glass
screen is working fine so is the touch my screen
i want to change it
i found these websites to order
http://www.repairsuniverse.com/motorola-...
http://zoeban.en.alibaba.com/product/570...
so is it the touch digitizer or something else ??
here i uploaded i picture of it
I'm just a normal user i don't understand too much
so if you can explain it, explain it simply
and
Thank You
Это хороший вопрос?
Оценка 2
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Hi. Unfortunately, the LCD and digitizer are fused to the display glass, so the entire unit must be replaced as one piece. We have a Display Assembly replacement guide. Good luck.
Был ли этот ответ полезен?
Оценка 4
3 Комментариев:
Thank you for your fast reply (:
but why are they selling the digitizer separately
if i can't change it without changing the display
sorry for asking alot of questions
but i just want to know
Thanks alot
из
welcome to the selling market on the internet. same thing with iPhone 4 and 4s. you can buy the lcd and touchscreen separate but its almost impossible to separate your own by yourself. and probably very hard to fuse them back together! don't be fooled and buy them as one piece...
из
Ok Thanks man really appreciate it (:
so i think i'm going to get it a whole new screen ):
из
- I have the same issue but on a 27" monitor - ACER T272HL
Touch screen works as per normal but one corner is shattered and there is a crack going all the way diagonally across the screen. ACER say they will replace the entire casing which includes the glass and touch stuff but that costs about 70% of buying a new one.... which I dont want to do anyways as it's not as great as I imagined it to be. Should have gone for the 22"!
Suggestions? Thanks :)
Оценка 0
Looking for a teardown for the Acer T232HL. It’s a 23” 10-point touchscreen. I’m interested in finding a 120 or 144hz replacement display to install behind the touchscreen.
Оценка 0
Добавьте свой ответ
Abdullah будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 19
За всё время: 20,224
