Model No. A1367 / 8, 16, 32, or 64 GB capacity
915вопросов Показать все
iPod touch stuck in recovery mode even after restore.
Hello,
Thanks in advance to anyone that can point me in the right direction for this issue.
I have an iPod touch (4th Gen) that has a completely blank (dark) screen. Connecting the device to my computer, I do hear the alert from the iPod to tell me a device is connected, and then iTunes notifies me it recognizes the iPod is in recovery mode and needs to be restored.
What I've tried:
  • Resetting. held sleep/wake and home button wile connected to power. nothing happens
  • Restoring in iTunes. Restore appears to complete. (no error messages)
  • DFU mode restore
As soon as restore completes, iTunes gives me the same message about detecting ipod in recovery mode.
Anything else I can try before cracking this thing open? Even then I still wouldn't know what to look for hardware-wise to fix.
Это хороший вопрос?
Оценка 7
2 Комментариев
If it in DFU mode then all you have to do is disconnect the iPod from your computer and press both the "Sleep/Wake" button and the "Home" button for 10 seconds or until the Apple logo appears, then it should boot as normal.
Read more about: How to get iPod out of recovery mode
из
this seems to work right now. looks like it worked thanks
из
Добавить комментарий
5 Ответов
Наиболее полезный ответ
If your ipod is in recovery mode you have no choice but to restore it. All the data on it is already lost if it is in recovery mode, you will have to restore it and when setting it up again at the end of the restore process your ipod will restart and you will have to set it up again as you did when it was new. In the process you will be given the option to restore it from and iTunes or iCloud backup. If you have been backing up to iCloud choose that (be sure to plug your ipod in to a wall charger as this will take hours to complete). If you haven't been backing up to iCloud choose restore from iTunes backup, then restore from the backup you created the last time you synced your
ipod. If it won't restore in recovery mode by connecting it to iTunes you will have to try putting it in DFU mode to restore it, as described here: http://www.ipadconverter-mac.com/ipod-to...
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
You told this guy to try stuff he already tried. Why?
из
my iPod 8gb keeps going to recovery mode when restore it and i cant get itunes
Оценка 1
1 Комментарий:
I am having the same issue.
из
http://www.youtube.com/watch?v=XavmOUgyi...
Watch the video, it work on my friend's
Оценка 0
DFU mode stands for DeviceFirmwareUpgrade.
1. Turn off your iPod touch.
2. Connect your iPod to the computer.
3. Hold the power and home button, when the Apple logo pops up stop holding the power button but still hold the home button.
4. Open iTunes and wait for it to tell you that its in restore mode.
Read more:http://www.iphone-mac.com/how-to-put-ipo...
Hope it can do you a favor.
Оценка 0
I just turned my laptop off and on. Ipod working fine now :)
Оценка 0
Добавьте свой ответ
Bobby будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 18
За последние 30 дней: 83
За всё время: 41,107
