Repair guides and support for your Apple Wireless Keyboard. Connect and command your Apple computer wirelessly.
How do you replace a single key?
Hi,
I'm in the unfortunate position where not only has one of my keys popped off, but one of the little metal teeth has broken too.
Is there a way for this to be fixed?
note: I might be off on the model number, but I'm going off what it says on the back of the keyboard
Это хороший вопрос?
Оценка -1
Добавить комментарий
Ответов (2)
Выбранное решение
If the "metal tooth" is on your keyboard and not part of the key, then it might be hard to fix a new key on here. Which would mean to replace the whole keyboard.
I haven't had the opportunity to take apart a newer keyboard yet so I'm not familiar with how they look inside, but I just got a new key for an old powerbook g4 from powerbookmedic.com. Perhaps you can find your key for your keyboard there and if possible you could replace it or the keyboard. I haven't checked here at ifixit either, so please do.
Был ли этот ответ полезен?
Оценка 0
You might be able to bend the metal back but if not then you'll have to buy a new keyboard. You can sell the old one on ebay for about $15 even though it's missing that key.
If you are able to bend the metal back, you can buy a replacement key on eBay for example:
http://www.ebay.com/itm/281064247677?ssP...
Оценка 0
Добавьте свой ответ
Will будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,225
