Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
Вопросов 20 Показать все
Can I fix the hinges without replacing the screen?
Hi
When you open this laptop, the screen flops backwards and must be propped against something to use it. Apart from that it is fine and there is nothing wrong with the display itself. The picture is great.
Is it possible to repair just the hinges? I don't think it's an economic repair if I need to buy the whole display assembly,
Thanks
Cath
Это хороший вопрос?
Оценка 2
Добавить комментарий
Ответов (3)
Выбранное решение
thanks for that - I'm not quite sure what part I need though - is this it?
-Cath
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
hi Cath
I would think this is the part for your Aluminum 17" G4
http://www.ifixit.com/PowerBook-Parts/G4...
I just noticed it's more expensive :( than the smaller clutch parts for the 15" model, although this contains both hinges and connecting frame
perhaps contact ifixit guys directly to confirm it's the right one
из
it IS possible. Unfortunately there doesn't seem to be a repair guide for that specific problem, but you can follow the guide for the 15" Powerbook. It won't be exactly the same, but it should be pretty darned close. Check out this link:
PowerBook G4 Aluminum 15" 1-1.5 GHz Inverter/Antenna Cables Replacement
This is for the inverter, but the hinges are right there once you get to the inverter. I'm not saying that it will be easy.... in fact getting it back together can be pretty tricky, but it is doable. I've actually done it myself on a 15" powerbook.
Оценка 0
the part you need to replace is the hinge "clutch" - it should be possible to do, if you're comfortable disassembling your machine. There are 2 clutches, left and right.
I've successfully replaced the hinge clutch on my previous laptop, a PowerBook G3 "Pismo". it required pretty well taking the whole unit apart - however repairing the hinges does not require you to replace the whole display. After taking apart the machine, it was clear which clutch was broken (in my case, only 1 was broken and needed replacing)
I bought the replacement clutch parts from another site several years ago (before I came across ifixit.com!) - but I notice you can buy these kind of parts here on ifixit too
I don't know the detailed inner construction of the Aluminum PB G4, but I think it's similar, as far as the display hinge goes.
the actual replacement of the hinge parts is easy - it's the disassembling the rest of the machine to get at them that's all the work.
good luck!
Оценка 0
Добавьте свой ответ
Cath будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 13
За всё время: 3,403
