Nintendo DSi Upper LCD/Speakers Replacement
Выберете то, что вам нужно
  1. Nintendo DSi Upper LCD/Speakers Replacement, Battery Cover Removal: шаг 1, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement, Battery Cover Removal: шаг 1, изображение 2 из 2
    • Unscrew the two Phillips screws securing the battery cover to the lower case.
    • The screws remain captive to the battery cover.
    • Grasp the battery cover and lift it out of the lower case.
    • If it's difficult to grasp, lightly tap the opposite side of the device.
  2. Nintendo DSi Upper LCD/Speakers Replacement, Taking out the Battery: шаг 2, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement, Taking out the Battery: шаг 2, изображение 2 из 2
    • Using a spudger tool (or your fingernail), lift up the battery from the top.
    • There's a small tab on the top of the battery to make removal easier.
    • The liquid damage indicator sits underneath the battery. Pry gently, or you may damage the indicator.
    • Grasp the battery and remove it from the DSi.
  3. Nintendo DSi Upper LCD/Speakers Replacement, Lower Case Assembly: шаг 3, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement, Lower Case Assembly: шаг 3, изображение 2 из 2
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
    • Depending on the age of your device, the rubber feet may crumble apart as you pry them out. If so, use a fine-tipped tool to scrape out any stuck pieces of rubber.
  4. Nintendo DSi Upper LCD/Speakers Replacement: шаг 4, изображение 1 из 1
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
  5. Nintendo DSi Upper LCD/Speakers Replacement: шаг 5, изображение 1 из 3 Nintendo DSi Upper LCD/Speakers Replacement: шаг 5, изображение 2 из 3 Nintendo DSi Upper LCD/Speakers Replacement: шаг 5, изображение 3 из 3
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  6. Nintendo DSi Upper LCD/Speakers Replacement: шаг 6, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement: шаг 6, изображение 2 из 2
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
  7. Nintendo DSi Upper LCD/Speakers Replacement, Wi-Fi Board: шаг 7, изображение 1 из 1
    • Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
  8. Nintendo DSi Upper LCD/Speakers Replacement: шаг 8, изображение 1 из 1
    • Pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
  9. Nintendo DSi Upper LCD/Speakers Replacement, Motherboard: шаг 9, изображение 1 из 1
    • Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
  10. Nintendo DSi Upper LCD/Speakers Replacement: шаг 10, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement: шаг 10, изображение 2 из 2
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following three ZIF sockets:
    • Lower touchscreen cable
    • Lower LCD cable
    • Power board cable
    • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
    • After flipping up the locking tabs on all three sockets, use your fingers or a pair of tweezers to gently pull the cables straight out of their sockets.
  11. Nintendo DSi Upper LCD/Speakers Replacement: шаг 11, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement: шаг 11, изображение 2 из 2
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the touchscreen ribbon cable retaining flap.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
  12. Nintendo DSi Upper LCD/Speakers Replacement: шаг 12, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement: шаг 12, изображение 2 из 2
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the dual camera ribbon cable retaining flap.
    • Use the tip of a spudger to pull the dual camera ribbon cable straight out of its socket.
  13. Nintendo DSi Upper LCD/Speakers Replacement: шаг 13, изображение 1 из 1
    • With the tip of a spudger, Pry the microphone antenna up off its socket on the motherboard.
  14. Nintendo DSi Upper LCD/Speakers Replacement: шаг 14, изображение 1 из 1
    • Remove the following four Phillips screws securing the motherboard to the DSi framework.
    • Three longer screws.
    • One short screw.
    • Pull the microphone and Wi-Fi antenna cables out of the notch cut into the motherboard near the headphone jack.
  15. Nintendo DSi Upper LCD/Speakers Replacement: шаг 15, изображение 1 из 3 Nintendo DSi Upper LCD/Speakers Replacement: шаг 15, изображение 2 из 3 Nintendo DSi Upper LCD/Speakers Replacement: шаг 15, изображение 3 из 3
    • Slightly lift the motherboard upwards to reveal the upper LCD ribbon cable above the ABXY buttons .
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the upper LCD ribbon cable retaining flap.
    • Remove the motherboard from the DSi.
  16. Nintendo DSi Upper LCD/Speakers Replacement, Lower LCD Assembly: шаг 16, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement, Lower LCD Assembly: шаг 16, изображение 2 из 2
    • Use the tip of a spudger to pry the metal backing of the lower LCD up from the DSi's framework.
    • Lift the lower LCD assembly out of the DSi.
  17. Nintendo DSi Upper LCD/Speakers Replacement, Upper LCD/Speakers: шаг 17, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement, Upper LCD/Speakers: шаг 17, изображение 2 из 2
    • Use a pushpin to remove the four plastic screw covers on the front bezel.
  18. Nintendo DSi Upper LCD/Speakers Replacement: шаг 18, изображение 1 из 1
    • Remove the four Phillips screws securing the rear bezel to the front bezel.
  19. Nintendo DSi Upper LCD/Speakers Replacement: шаг 19, изображение 1 из 3 Nintendo DSi Upper LCD/Speakers Replacement: шаг 19, изображение 2 из 3 Nintendo DSi Upper LCD/Speakers Replacement: шаг 19, изображение 3 из 3
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
    • Slightly close the case of the DSi and lift the rear bezel straight up out of the DSi.
  20. Nintendo DSi Upper LCD/Speakers Replacement: шаг 20, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement: шаг 20, изображение 2 из 2
    • Continue de-routing the microphone and Wi-Fi antenna cables through the opening located on the bottom DSi's framework.
  21. Nintendo DSi Upper LCD/Speakers Replacement: шаг 21, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement: шаг 21, изображение 2 из 2
    • Remove the five Phillips screws securing the power board to the DSi's framework.
    • Lift and remove the power board from the DSi.
  22. Nintendo DSi Upper LCD/Speakers Replacement: шаг 22, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement: шаг 22, изображение 2 из 2
    • Push the metal hinge pin inward on the D-pad side of the front lower panel with the tip of a spudger.
    • The pin should move about 3 mm and stop. It is not necessary to try to completely remove the pin.
  23. Nintendo DSi Upper LCD/Speakers Replacement: шаг 23, изображение 1 из 3 Nintendo DSi Upper LCD/Speakers Replacement: шаг 23, изображение 2 из 3 Nintendo DSi Upper LCD/Speakers Replacement: шаг 23, изображение 3 из 3
    • Slightly detach the lower and upper halves of the DSi.
    • Do not completely separate both halves yet. There are several ribbon cables that remain threaded through both panels.
    • De-route the upper LCD and dual camera ribbon cables through the slit near the ABXY side of the front lower panel.
    • Separate the lower and upper halves from each other.
  24. Nintendo DSi Upper LCD/Speakers Replacement: шаг 24, изображение 1 из 1
    • Using your fingers, grasp the microphone cable and de-route it through the hinge.
    • The microphone will likely pop out of its housing, so it is probably easier to completely remove it at this point.
    • De-route the Wi-Fi cable through the hinge.
  25. Nintendo DSi Upper LCD/Speakers Replacement: шаг 25, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement: шаг 25, изображение 2 из 2
    • Tightly coil the display and dual camera ribbon cables enough to push them through the steel hinge tube.
    • Remove the steel hinge tube.
    • Carefully push both coiled ribbon cables through the tube molded into the front upper panel.
  26. Nintendo DSi Upper LCD/Speakers Replacement: шаг 26, изображение 1 из 1
    • Pry the front-facing camera straight up out of its housing in the front bezel.
  27. Nintendo DSi Upper LCD/Speakers Replacement: шаг 27, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement: шаг 27, изображение 2 из 2
    • Lift the rear-facing camera out of its housing in the front bezel.
    • Remove the dual camera cable assembly from the DSi.
  28. Nintendo DSi Upper LCD/Speakers Replacement: шаг 28, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement: шаг 28, изображение 2 из 2
    • De-route the Wi-Fi antenna cable from its channel in the front bezel.
    • Lift the Wi-Fi antenna board straight up and remove it from the DSi.
  29. Nintendo DSi Upper LCD/Speakers Replacement: шаг 29, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement: шаг 29, изображение 2 из 2
    • Use the flat end of a spudger to pry the right speaker straight up and out of its housing in the front upper panel.
    • Lift the right speaker and set it on top of the upper LCD.
  30. Nintendo DSi Upper LCD/Speakers Replacement: шаг 30, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement: шаг 30, изображение 2 из 2
    • In the same manner as previously described, remove the left speaker.
    • De-route the left speaker cables from underneath the upper LCD.
    • Lay the left speaker on top of the upper LCD.
  31. Nintendo DSi Upper LCD/Speakers Replacement: шаг 31, изображение 1 из 2 Nintendo DSi Upper LCD/Speakers Replacement: шаг 31, изображение 2 из 2
    • Cautiously wedge the flat end of spudger underneath the upper LCD.
    • Loosen the adhesive by running the spudger along the perimeter of the upper LCD.
    • Lift the upper LCD by its upper right corner and remove it from the front upper panel.
  32. Nintendo DSi Upper LCD/Speakers Replacement: шаг 32, изображение 1 из 1
    • Desolder the speakers from the upper LCD by heating up the solder joints with a soldering iron and simultaneously using a pair of tweezers to pull the speaker wires away from the logic board.
    • If you have never soldered before, we have a guide that makes it easy.
Заключение
30 участников успешно повторили данное руководство.
12 Комментариев
The tricky part is getting the upper screen and black ribbon through the hinge. I found that curling them and pushing them through a drinking straw that was cut short first and then pushing the straw through the hinge hole made it a whole lot easier.
Damian - Ответить
So true. I just broke my second ribbon cable while replacing the case. While most repairs on the dsi are relatively easy, this ribbon cable makes any repairs that involve it a nightmare.
Brendan Smith -
I curled the larger (new) cable the same way the smaller one was already curled. Just spend some time doing that until it was shaped that way and it was a lot easier to get both through the molded tube and ring.
Tplan -
I used this guide for change the cover broken by my son.
Thank you
Bompa (Italy)
Bompa - Ответить
While doing this I accident messed something up. When I power on the DSi, the bottom screen just flashes and the DS turns off. What did I do wrong?
Ruben Colon - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 19
За последние 7 дней: 158
За последние 30 дней: 515
За всё время: 56,457
