在正式开始前,我们先复习一下手机特性。
5.5英寸 IPS屏 1920*1080分辨率
1300百万2.0光圈双闪光灯后置摄像头。前置500万像素摄像头。
高通骁龙801 2.5Ghz四核摄像头
3Gb LPDDR3 1866MHz 运行内存
64GB eMMC 5.0 存储空间(16GB可选)
802.11b/g/n/ac Wi-Fi, 蓝牙 4.0, USB OTG, GPS/GLONASS, NFC
令人印象深刻的硬件,可以肯定 - 但这是一个拆卸,而HTC one给我们留下了一点受到晚期的创伤。 这里希望“Plus”代表“比友商的手机更可修”
我们拉出内部保护盖子来接近电池连接器。 如果我们的计算正确,一加 一的电池即将被移除。
我们的撬棒执行必要的算术,3.8 V,3100 mAh LiPo电池是我们(和您的)进行检查。
与其2800mAh(Galaxy S5)和2600mAh(HTC One M8)竞争对手相比,它的表现很好。
对于那些读不懂中文的人,这款电池的最大充电电压为4.35 V,并有以下警告和注意事项(释义):
只能使用授权的充电器
充电时请保持通风
不要拆解,短路或穿刺
前置摄像头和后置摄像头均由Sunny Optical Technology设计。
后置摄像头标有P13N05A,前置摄像头标识为P5V35A。
在Project Tango中,我们也遇到了Sunny Optical Technology设计的相机模组。
根据一加 一规格页面的细节,1300万像素后置摄像头配有Sony Exmor IMX 214CMOS图像传感器。
我们很快就用完了拉丁语的口吻,但芯片呢?还没接近呢!背面包含:
东芝THGBMBG9D8KBAIG eMMC 5.0 64 GB机载存储
Skyworks SKY77629-21功率放大器模块
高通WCN3680 802.11ac / FM / BT 4.0组合芯片
高通WTR1625L射频收发器
SkyworksSKY85709WLAN前端模块
Synaptics S3508A触摸屏控制器
Особая благодарность этим переводчикам:
100%
Leon赵国鑫помогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
50 Комментариев
Hey guys, nice teardown. I'm guessing you probably already gave out your spare invites to your fellow workmates or friends but if you haven't I'd be eternally grateful for one.
Are you kidding me with this?
Haha some ppl really can't hold there s**t together
I bought 2 OPOs (sold one to a client, kept the other), both over a month ago, and have not received any invites. The invites I bought were $ 23.00 and $ 9.00, respectively, but now they seem to be in VERY short supply, and are going for bigger bucks. Not sure what's up with that!
PJ Blank -
Thank you. I was really waiting for this. OnePlus said they made the battery unremoveable to make the phone thinner, because they don't have to cover up the cables underneath.
That being said, do you think it's possible we will see a battery hack kit appearing on eBay? One that has a battery connector extender that extends to connector pins in the battery compartment and then a matching battery that can just be popped out?
