Введение
A broken charging rail will cause an inability to connect directly to the Nintendo Switch console or an inability to charge the Joy-Con. This guide will show you how to replace the charging rail on the Left Joy-Con controller.
Before using this guide, check for potential bent pins on the charging rail that can be bent back. If possible, test if the Joy-Con can be charged from an external source or check if the problem is actually with the sensor rail on the Nintendo Switch console.
If the problem is the Nintendo Switch sensor rail, then follow this guide: Nintendo Switch Left Joy Con Sensor Rail Replacement
Выберете то, что вам нужно
Use the Tri-point Y00 screwdriver to remove the four 6 mm screws from the back of the Joy-Con.
Insert the opening pick into the bottom of the Joy-Con, then move it towards the L and ZL buttons.
Lift the back shell off the Joy-Con and place it to the side.
Insert a spudger or prying tool beneath the battery wires and gently pry the battery plug out of the socket on the motherboard.
Once the battery plug is removed from the socket, lift the battery off the mid-frame.
Unscrew the three golden 3 mm Phillips #000 screws holding the mid-frame in place.
Lift the mid-frame off the motherboard and place it to the side.
Инструмент, используемый на этом этапе:Tweezers$4.99
Unlatch the ZIF connector that is locking the ribbon cable on the mid-frame to the motherboard.
Use tweezers to gently pull the ribbon cable out of the ZIF connector.
Unlatch the two ZIF connectors that are locking the ribbon cables on the charging rail to the motherboard.
Use tweezers to gently pull the ribbon cables out of the ZIF connectors.
Remove the 2 mm Philips #000 screw holding the charging rail onto the back shell.
Remove the charging rail from the back shell.
Use the Phillips #000 screwdriver to remove the two 3 mm screws at the center of the PCB.
Remove the PCB from the charging rail.
Place the SL, SR and sync buttons into the new charging rail and make sure the tabs on the SL and SR buttons fit into their respective socket grooves.
Place the PCB over the buttons and secure it in place using the two golden 3 mm Phillips #000 screws.
Align the charging rail with the two standoffs on the back shell.
Secure the rail onto the back shell using the 2 mm Phillips #000 screws.
Use tweezers to insert the ribbon cables for the charging rail into the ZIF connectors on the motherboard.
Press down on the latch for each ZIF connector to secure the ribbon cables in place.
Use tweezers to insert the ribbon cable for the mid-frame into the ZIF connector on the motherboard, with the golden pins facing upwards.
Press down on the ZIF connector latch to secure the ribbon cable in place.
Place the the mid-frame over the motherboard.
Using Philips #000 screwdriver, secure the three golden 3 mm screws of the mid-frame onto the motherboard.
Place the battery into the mid-frame.
Use tweezers to align the battery plug over the socket and with a pry tool or an object with a flat edge, press the plug into the socket.
Align the charging rail into the notch on the left side of the Joy-Con.
Apply even pressure on both sides of the Joy-Con until the two shells click together.
Screw in the four 6 mm Tri-point Y00 screws into the back of the Joy-Con.
33 человек успешно провели ремонт по этому руководству.
16 Комментариев
I did this and still doesn’t work. I also changed the rail on the console side too. Very carefully of course. Any ideas?
Hey Luis,
Can you give me more detail on the problem? Like is the Joy-Con not being detected when it’s plugged in or is it not charging. If possible, can you test the console rail with a working Joy-Con?
If the Joy-Con is not charging, it could also be a battery problem. If you are comfortable with it, I would suggest swapping out the battery with a working one from the other Joy-Con to see if it solves the problem. You should probably attempt this after double-checking the connections for potential tears or if the connectors are too loose in the sockets.
Hi, I need help. My left Joy-Con is not charging because of the ZIF connector for the charging rail ribbon has been detached and I have lost it. Is there a way to fix this problem?
Honestly, I would recommend replacing the entire Motherboard, unless you can find a trusted repair shop to solder it on.
I damaged the ZIF connector for the battery on my Switch. It works with some pressure and perfect alignment, but I've had issues ever since I damaged it during repairs :/
I'm going to swap it with a functional motherboard, I would advise you do the same.
Hello need a little help. the ribbon cable will not stay connected. and it will not charger. Any thing will help.
