01502837 Reed Switch Gen 2 Installation
Выберете то, что вам нужно
Рекомендуемый документ
    • Lift should be off.
    • Open access panel where reed switch is located. Use an Allen wrench.
    • Disconnect and remove old reed switch. (with green contact block)
    • It is necessary to remove aluminum post to remove reed switch from plate.
    Спросите у FixBot
    • Cut off any existing in line connector on lift side wiring.
    • Strip wires back as shown below to slide into new butt connectors.
    Спросите у FixBot
    • Crimp the butt connectors to the wires that were just prepped.
    • At this point slide the reed switch mounting bracket over the wires on the lift and then you can start connecting the new reed switch.
    Спросите у FixBot
    • Connect new reed switch to lift using red butt connectors (included) to crimp wiring.
    • Red to White and Black to Black.
    • Pull test crimp connections, redo if needed.
    Спросите у FixBot
    • Use head gun to melt solder bulb and shrink tubing over connection. Orient butt connector and heat gun such that reed switch is not exposed to heat. You will see the middle section start to flow as it heats up.
    • It may be helpful to temporarily clamp reed switch plate to gate crossmember to make it easier to insert wire into crimp connector. If switch side wiring has insufficient length to perform rework operation, open black hinged wire route cover and pull more length through.
    Спросите у FixBot
    • Push wiring back into gate away from reed switch and latch slider.
    • Reinstall cover plate with Allen head flat head screws.
    • Use caution when touching the reed switch mounting plate as it may have indirectly been affected by the heat gun during installation.
    Спросите у FixBot
Заключение
Perform an Operations Check to confirm new part is installed correctly.
Прикрепленные документы
Tanisha Meredith
Участник с: 11/08/22
3 252 Репутация
Автор 28 руководств
Команда
The Home Depot Участник The Home Depot
Community
24 728 членов
Автор 67 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 33
За всё время: 455
