Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Begin by placing the jack under the subframe behind the front passenger wheel. Leave enough room for the jack stand to be placed between the jack and front wheel.
Use the jack to raise the car enough to comfortably work under it.
Place the jack stand between the jack and front wheel.
Slowly lower the car until the jack stand supports the car and the jack does not. Remove the jack.
Locate the 19 mm hex oil drain plug. It is on the passenger side of the car, facing towards the rear of the car.
Place the oil drain pan below the oil drain plug.
Use a 19 mm box end wrench to turn the oil drain plug counter-clockwise until you can turn it by hand.
Finish removing the oil drain plug with your hand. Oil will begin streaming out of the oil pan when you finish removing the plug
Once the draining oil has slowed to a drip, wipe the old oil off the area around the drain hole with a clean rag or towel.
Place the oil drain plug back over its hole and turn it clockwise by hand as far as possible.
Finish tightening the oil drain plug with the 19 mm box end wrench until it is snug.
Locate the hood release lever. It is below the left side of the driver's console.
Pull the hood release lever until you hear the hood click open.
Locate the hood release latch. It will be under the hood at about the center line of the car.
Pull up on the hood release latch and simultaneously lift the hood open.
Place the hood prop rod into the hole in the hood marked by an arrow.
On the back passenger side of the engine bay, you will find a space where you can see the back of the engine.
Look through the space at the back of the engine, you will find the oil filter below the intake system and next to the alternator.
Reposition the oil drain pan to catch any oil that will spill out when you remove the oil filter.
Reach into the opening and turn the oil filter counter-clockwise by hand.
When the oil filter comes off, remove it from the engine bay with the open end facing up to reduce the amount of oil spilled.
Place the oil filter in the oil drain pan with the open end facing down.
Dip a clean gloved finger into a new bottle of oil.
Use your wet finger to spread a thin layer of oil over the gasket of the new oil filter.
Wipe off excess oil from your hands and the filter. The oil may make handling and reinstalling the filter difficult.
Place the new filter onto the engine's oil filter threads, being careful not to get dirt and debris on the wet oil filter gasket.
Turn the oil filter clockwise by hand until it is snug. Tightening should require a moderate amount of your strength, but not all of it.
Remove the oil drain pan from under the car.
Place the jack back under the car's subframe and raise the car until the jack stand is no longer supporting it.
Remove the jack stand.
Slowly lower the jack until it no longer supports the car.
Locate the oil filler cap. It is on the front passenger side of the engine's valve cover.
Twist the cap counter-clockwise by hand and pull it off the valve cover.
Place the funnel into the oil filler hole.
Pour 4 quarts of 10W-30 oil into the engine. Use one hand to stabilize the funnel to help prevent spills.
Remove the funnel, place the oil filler cap over the oil filler hole and twist the cap clockwise until it is snug.
Locate the oil dipstick. It is just below the front passenger corner of the engine. The dipstick has a bright yellow handle.
Pull out the oil dipstick, wipe it off, place it all the way back into its hole and remove it again.
Check the oil level on the end of the dipstick. It should be between the two holes or slightly above the top one.
Add oil if the oil level is below the bottom hole of the dipstick. Place the oil dipstick all the way back in its hole.
Support the hood with one hand and use your other hand to place the hood prop rod back into its holder.
Gently lower the hood until it clicks into the secondary latch.
Press firmly on the edge of the hood until you hear the primary latch engage.
Start the car and look for leaks under the car. If there are leaks, shut the car off and determine if the drain plug or filter need to be tightened, or if a part has been damaged.
After running the engine for a few minutes, let it cool down for at least an hour and re-check the oil level. If the oil level is more than a 1/2" above the top hole of the dipstick you will need to drain oil. If the oil level is below the bottom hole of the dipstick you will need to add oil.
Allow 12-24 hours for all the oil to drain out of your old oil filter.
Take your old oil and filter to a recycling facility. Most auto parts stores and repair shops accept these at no charge. In addition, some cities and/or counties have a service where they will collect used oil and filters from your home. For more information, see the American Petroleum Institute's web page on used motor oil collection and recycling.
16 участников успешно повторили данное руководство.
5 Комментариев
What if it's smoky
Im a single woman in my 40's. Never had good business with mechanics in the past. After reading your instruction. There is a new confidence .So now feeling like oil change is something I can do myself.
Thank you
