2007-2013 Chevrolet Silverado Battery Replacement
Выберете то, что вам нужно
  1. 2007-2013 Chevrolet Silverado Battery Replacement, Open the Hood: шаг 1, изображение 1 из 3 2007-2013 Chevrolet Silverado Battery Replacement, Open the Hood: шаг 1, изображение 2 из 3 2007-2013 Chevrolet Silverado Battery Replacement, Open the Hood: шаг 1, изображение 3 из 3
    • Make sure the engine is completely turned off and the key is out of the ignition before beginning.
    • The hood release handle is located on the driver's side to the left of the emergency brake pedal.
    • Pull on the hood release handle to pop the hood.
    • To open the hood, reach into the gap at the front of the truck and feel for the latch in the middle. Push it to the left to release it and lift up on the hood.
  2. 2007-2013 Chevrolet Silverado Battery Replacement, Locate the Battery Compartment: шаг 2, изображение 1 из 1
    • The battery is located in the back left corner of the engine bay, partially covered by an engine bay brace.
  3. 2007-2013 Chevrolet Silverado Battery Replacement, Remove the Engine Bay Brace: шаг 3, изображение 1 из 3 2007-2013 Chevrolet Silverado Battery Replacement, Remove the Engine Bay Brace: шаг 3, изображение 2 из 3 2007-2013 Chevrolet Silverado Battery Replacement, Remove the Engine Bay Brace: шаг 3, изображение 3 из 3
    • Remove the four bolts holding the engine bay brace to the body of the truck with a 13 mm socket and socket wrench. Remove the brace and set it to the side.
  4. 2007-2013 Chevrolet Silverado Battery Replacement, Remove the Battery Hold Down: шаг 4, изображение 1 из 3 2007-2013 Chevrolet Silverado Battery Replacement, Remove the Battery Hold Down: шаг 4, изображение 2 из 3 2007-2013 Chevrolet Silverado Battery Replacement, Remove the Battery Hold Down: шаг 4, изображение 3 из 3
    • Locate the battery hold down, which is a small block held down on the right side of the battery compartment.
    • Use at least a 6-inch socket wrench extension to reach the 13 mm bolt and loosen it up.
    • Once it's completely loosened, reach down and pull out the bolt and the battery hold down block.
  5. 2007-2013 Chevrolet Silverado Battery Replacement, Remove the Cables from the Battery Terminals: шаг 5, изображение 1 из 1
    • Locate the red positive cable and the black negative cable, both of which need to be removed using a 10 mm socket.
    • Remove the black negative cable first (and reinstall it last), which will prevent the possibility of shorting the battery to ground.
  6. 2007-2013 Chevrolet Silverado Battery Replacement: шаг 6, изображение 1 из 3 2007-2013 Chevrolet Silverado Battery Replacement: шаг 6, изображение 2 из 3 2007-2013 Chevrolet Silverado Battery Replacement: шаг 6, изображение 3 из 3
    • Loosen the 10 mm bolt on the black negative terminal just enough so you can lift it up and remove the cable.
    • Push the cable back and out of the way. A simple trick is to rest it on one of the engine bay braces to keep it from springing back.
  7. 2007-2013 Chevrolet Silverado Battery Replacement: шаг 7, изображение 1 из 3 2007-2013 Chevrolet Silverado Battery Replacement: шаг 7, изображение 2 из 3 2007-2013 Chevrolet Silverado Battery Replacement: шаг 7, изображение 3 из 3
    • Flip up the terminal cover on the red positive terminal and loosen the 10 mm bolt.
    • Lift up on the cable and move it out of the way. Resting it on the coolant reservoir keeps it from springing back.
  8. 2007-2013 Chevrolet Silverado Battery Replacement, Remove the Battery: шаг 8, изображение 1 из 3 2007-2013 Chevrolet Silverado Battery Replacement, Remove the Battery: шаг 8, изображение 2 из 3 2007-2013 Chevrolet Silverado Battery Replacement, Remove the Battery: шаг 8, изображение 3 из 3
    • The battery may have carrying handles that you can flip up if they're not already.
    • Grab onto the handles with both hands and slowly lift the battery out of the battery compartment.
    • Batteries are very heavy (around 40 lbs.), so make sure you're able to safely lift the weight.
Заключение
Follow these instructions in reverse order to install the new battery and reassemble components. Make sure to connect the black negative cable last to prevent shorting the battery to ground.
12 участников успешно повторили данное руководство.
Craig Lloyd
Участник с: 02/10/16
35 480 Репутация
Автор 82 руководств
5 Комментариев
Nicely done. You made it very straight forward. No guessing necessary!
nancy913 - Ответить
Thanks for including the nut sizes!
Jake - Ответить
Ty for these instructions made it easy getting buttery out and back in
Pamela Collins - Ответить
Well done. You made it extremely clear. There's no need to make assumptions!
redactle
Leon Watts - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 24
За последние 7 дней: 159
За последние 30 дней: 710
За всё время: 58,181
