Введение
When using a drone, the propellors rotate and move so that the drone can function. As a result, the propellors are a component that will experience heavy wear and tear throughout the lifetime of the device.
If your drone has a broken propellor (diagnosed either by observation or through our troubleshooting page), replace it with this guide. There are no required tools for this replacement.
Выберете то, что вам нужно
Power off the drone by holding down the power button.
Remove the battery by disconnecting it from the main battery connector.
Press the power button again to ensure all electricity is discharged.
Hold down the motor assembly and twist the propeller clockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
Hold down the motor assembly and twist the propeller counterclockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
This is the motor assembly.
Ensure that the propeller cap color (black or silver) matches the propeller screw cap color.
To reassemble your device, follow these directions in reverse order.
Еще один человек закончил это руководство.
