ASUS PadFone X Front Facing Camera Replacement
Выберете то, что вам нужно
    1. ASUS PadFone X Front Facing Camera  Replacement, Motherboard: шаг 1, изображение 1 из 2 ASUS PadFone X Front Facing Camera  Replacement, Motherboard: шаг 1, изображение 2 из 2
      • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
      • Work your way around the phone until the entire back cover is loose.
      Спросите у FixBot
      Добавить комментарий
    2. ASUS PadFone X Front Facing Camera  Replacement: шаг 2, изображение 1 из 2 ASUS PadFone X Front Facing Camera  Replacement: шаг 2, изображение 2 из 2
      • Remove the thirteen 3.6 mm screws using the Torx T5 bit in the screwdriver.
      Спросите у FixBot
    3. ASUS PadFone X Front Facing Camera  Replacement: шаг 3, изображение 1 из 2 ASUS PadFone X Front Facing Camera  Replacement: шаг 3, изображение 2 из 2
      • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
      • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
      Спросите у FixBot
    4. ASUS PadFone X Front Facing Camera  Replacement: шаг 4, изображение 1 из 1
      • Using the plastic blue plastic opening tool, gently disconnect the battery cable from the motherboard.
      • Applying too much force will damage the connector.
      Спросите у FixBot
    5. ASUS PadFone X Front Facing Camera  Replacement: шаг 5, изображение 1 из 2 ASUS PadFone X Front Facing Camera  Replacement: шаг 5, изображение 2 из 2
      • Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
      • The battery pack is held on by double sided tape, you will have to apply some force when prying out the battery.
      Спросите у FixBot
    6. ASUS PadFone X Front Facing Camera  Replacement: шаг 6, изображение 1 из 1
      • Using a spudger, pry the vibration motor connector from the motherboard.
      Спросите у FixBot
    7. ASUS PadFone X Front Facing Camera  Replacement: шаг 7, изображение 1 из 1
      • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
      • Applying too much force will damage the conector
      Спросите у FixBot
    8. ASUS PadFone X Front Facing Camera  Replacement: шаг 8, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      • Using the tweezers, remove the rear camera from the Padfone X.
      • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
      Спросите у FixBot
    9. ASUS PadFone X Front Facing Camera  Replacement: шаг 9, изображение 1 из 2 ASUS PadFone X Front Facing Camera  Replacement: шаг 9, изображение 2 из 2
      • Insert the tip of the flat head screwdriver between the panel and the metal clip then gently push down until the clip is slightly bent away from the panel.
      • Do this for all the clips holding the panel down.
      • After all clips are bent away, remove the panel.
      Спросите у FixBot
    10. ASUS PadFone X Front Facing Camera  Replacement: шаг 10, изображение 1 из 2 ASUS PadFone X Front Facing Camera  Replacement: шаг 10, изображение 2 из 2
      • Disconnect the first connector by prying it upward using the blue plastic opening tool.
      • Disconnect the second connector by first lifting the lock then pulling the connector outward.
      Спросите у FixBot
    11. ASUS PadFone X Front Facing Camera  Replacement: шаг 11, изображение 1 из 3 ASUS PadFone X Front Facing Camera  Replacement: шаг 11, изображение 2 из 3 ASUS PadFone X Front Facing Camera  Replacement: шаг 11, изображение 3 из 3
      • Insert the tip of the blue plastic opening tool under the motherboard and gently pry upward.
      • Work your way around until the motherboard is free.
      Спросите у FixBot
    12. ASUS PadFone X Front Facing Camera  Replacement: шаг 12, изображение 1 из 1
      • Flip the motherboard over and locate the front facing camera.
      • Using the tweezers gently remove the black locking mechanism.
      • The black locking mechanism is very fragile and extreme care should be exercised during removal.
      Спросите у FixBot
    13. ASUS PadFone X Front Facing Camera  Replacement: шаг 13, изображение 1 из 2 ASUS PadFone X Front Facing Camera  Replacement: шаг 13, изображение 2 из 2
      • Use the tweezers to gently pull on the connector to remove the camera.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Keith Cooper
Участник с: 01/24/17
122 Репутация
1 руководство автора
Команда
IUPUI, Team 2-1, Baechle Spring 2017 Участник IUPUI, Team 2-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G1
4 членов
Автор 48 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 9
За последние 30 дней: 45
За всё время: 660
