Введение
The hard drive is the component of the computer that stores information such as files and programs. You will want to replace your hard drive if the drive is failing, almost out of storage space, or has slow reading and writing speeds. This guide will walk you through the process of replacing the hard drive in the Asus Vivobook Flip TP501U.
Выберете то, что вам нужно
Open the laptop until it is flat and lay it screen down.
Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
Remove two 4.8mm Phillips from the corners of the device.
Turn the device face up.
Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
Remove the keyboard panel completely.
Unscrew the five 4.8mm Phillips #00 screws holding in the hard drive mounting bracket.
Slide the mounting bracket towards the battery to disconnect the hard drive from the motherboard.
Unscrew the hard drive from the mounting bracket.
Remove the hard drive from the mounting bracket.
