Введение
All batteries wear out in time and lead to poor battery life. This guide will show you how to replace your battery on the Acer Aspire E5-573G
Инструменты
Запчасти
No parts specified.
Unscrew the single (5mm) Philips head screw holding the drive in place.
Unscrew all 17 (5mm) Philips head screws from the bottom.
Unscrew the 3 (2.5mm) Philips head screws underneath the optical drive.
Run a pick around the edge of the laptop (between the two parts) to open it.
Lift the left side of the case up and unplug the speaker cable before fully taking the bottom off.
6 участников успешно повторили данное руководство.
2 Comments
Where can i buy a battery replacement for my aspire e5-573g-59c3?
Here are some links I found with a quick search of your model. These should work, but you should make sure they do before you order.
This link specifically mentions your model and is in the US
https://www.walmart.com/ip/BattPit-Lapto...
These links are from Canada and appear to be the same battery
http://www.battdepot.com/ca/model/notebo...
