Введение
Is your motherboard dead, preventing your device from functioning? If so, here is a guide to remove your motherboard.
Выберете то, что вам нужно
Make sure the device is turned off and disconnected from any power source.
To disconnect the tablet from the keyboard attachment, open the laptop and lift the tablet component up from the keyboard dock.
Starting from the corner of the tablet, use a jimmy to create a gap between the screen and the back covering.
Insert a metal spudger in the gap that you created with the Jimmy.
Slowly maneuver the metal spudger along the perimeter of the tablet to pry the screen and back covering apart.
Separate the back covering from the screen.
Using the Phillips #00 screwdriver, unscrew the two 2mm screws at the bottom of the tablet and open the ZIF latch.
Gently remove the gold ribbon cable covering the battery and set it aside.
Using the Phillips #00 screwdriver, unscrew the two 2mm screws at the top right of the battery.
Peel the three shiny black stickers from the battery (top left, bottom right, and bottom left), but keep them attached to the motherboard.
Use the spudger to separate the battery from glue that holds the battery to the screen. Carefully pry the battery from the tablet.
Using a spudger, disconnect the two ribbon cables on the top right and the three on the bottom left of the motherboard.
Use a Phillips #00 screwdriver to remove the five 2mm screws from the motherboard. There are two on the left edge and three on the bottom edge of the motherboard.
Using the spudger, pry the speaker from the right side of the tablet.
Lift the red and black wires attached to speaker on right side out of the track to where it connects to motherboard and the speaker on the left side.
Using the spudger, pry the speaker from the left side of the tablet.
Use a spudger to create a gap between motherboard and back covering.
Using the spudger, gently pry the motherboard away from the back covering.
Gently lift and remove the motherboard and speakers from tablet.
2 участников успешно повторили данное руководство.
