Введение
If your Acer Swift 3 2022 touchpad is losing its sensitivity, follow this guide to replace it. Before deciding to replace the touchpad make sure the settings are up to date. Before starting the replacement process make sure you have all the correct screwdrivers! For more information view our troubleshooting page.
Выберете то, что вам нужно
Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
Use the iFixit opening tool to pry open the back of the device.
Remove the bottom cover from the laptop.
Remove the two 5 mm screws on the sides of the battery using a TR6 Torx screwdriver.
Before disassembly, place a sheet of paper or cloth material between the touchpad and the screen.
Using the iFixit opening tool, flip up the black plastic retaining flap holding the white ribbon cable.
Pull the black flap of film up to identify the two screws.
Remove the two 2 mm screws using a JIS #1 screwdriver.
Еще один человек закончил это руководство.
