Adjust turntable speed
Выберете то, что вам нужно
  1. Adjust turntable speed, Adjust turntable speed: шаг 1, изображение 1 из 2 Adjust turntable speed, Adjust turntable speed: шаг 1, изображение 2 из 2
    • First method is to put a pattern disc on the table such as the shown one. There are also print templates on the web.
    • These patterns on the disc interact with light. Except it doesn't work with most led lights. So you need an old fashion glowing filament or fluorescent lamp because they are flickering with our power line frequnecy.
    • On the patterned disc you see two main areas with thicker lines. The inner three pattern circles are for 60 Hz e.g. north america and the outer patterns are for 50Hz.
    • The 3 pattern circles itself representing 3 different speeds. 33 1/3, 45 and 78 rpm. The stroboscopic effect occurs if the flickering light is directed to the pattern disc and the corresponding speed of the table makes the patter look as it stands still. So the pattern in the corresponding circle isn't moving, if the speed setup is right.
  2. Adjust turntable speed: шаг 2, изображение 1 из 2 Adjust turntable speed: шаг 2, изображение 2 из 2
    • By adjusting two screews on the bottom side of the turntable you can affect the motor speed and thus bring the pattern to stop. Here a DUAL player is shown who has direct access to two motor screws. One for 33 1/3 rpm and one for 45 rpm.
  3. Adjust turntable speed: шаг 3, изображение 1 из 2 Adjust turntable speed: шаг 3, изображение 2 из 2
    • On this more sopisticated technics player are marks on the table and a red light.
    • With the marked wheel you can adjust the speed very easy.
Заключение
This is the way to easily improve your turntable sound.
2 человек успешно провели ремонт по этому руководству.
Christian
Участник с: 09/04/20
1 252 Репутация
Автор 3 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 35
За последние 30 дней: 223
За всё время: 795
