Введение
This guide allows you to replace the motherboard of the Smash Bot. A soldering iron will need to be used for this, directions on how to solder can be found here.
Выберете то, что вам нужно
Lift and slide the batter cover away from the tab holding it in place at the bottom.
Peel back the four decal stickers that hold the front and back of the bot together.
Use the plastic opening tool to pry the front and back of the lower body apart.
Carefully remove the back of the bot from the front.
Use the soldering iron to remove the two wires from the motherboard. Directions on how to solder can be found here.
2 участников успешно повторили данное руководство.
