AirPods Charging Case Battery Replacement
Выберете то, что вам нужно
Видеообзор
  1. AirPods Charging Case Battery Replacement, AirPods charging case battery replacement: шаг 1, изображение 1 из 2 AirPods Charging Case Battery Replacement, AirPods charging case battery replacement: шаг 1, изображение 2 из 2
    • It is difficult to teardown the AirPods charging case because the charging case features 2 fixed points and the middle part is glued with adhesive. The charging case can easily be damaged by careless methods of dissasembly.
  2. AirPods Charging Case Battery Replacement, Creating a pry tool: шаг 2, изображение 1 из 3 AirPods Charging Case Battery Replacement, Creating a pry tool: шаг 2, изображение 2 из 3 AirPods Charging Case Battery Replacement, Creating a pry tool: шаг 2, изображение 3 из 3
    • There is currently no special repair tool for the AirPods. Therefore, we need to make a set of disassembly tools.
    • Be careful when handling sharp and thin metal as it can easily injure your hands.
    • Make a pry piece with a 0.1mm steel plate. Firstly, cut the steel plate into the shape of a pry piece with a pair of scissors.
    • Grind the edges of the pry piece with a sheet of sandpaper.
  3. AirPods Charging Case Battery Replacement, Preparing the pry tool: шаг 3, изображение 1 из 2 AirPods Charging Case Battery Replacement, Preparing the pry tool: шаг 3, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Bend the pry piece with a cutting nipper.
    • Use tweezers to make a shielding plate.
  4. AirPods Charging Case Battery Replacement, Prepare for opening the case: шаг 4, изображение 1 из 3 AirPods Charging Case Battery Replacement, Prepare for opening the case: шаг 4, изображение 2 из 3 AirPods Charging Case Battery Replacement, Prepare for opening the case: шаг 4, изображение 3 из 3
    • To avoid damaging the charging case, wrap high-temperature tape around it.
    • Next, insert the pry piece into the seam of the two fixed points.
    • Use the pry knife to pry out a gap.
  5. AirPods Charging Case Battery Replacement, Start opening case: шаг 5, изображение 1 из 2 AirPods Charging Case Battery Replacement, Start opening case: шаг 5, изображение 2 из 2
    • Insert the shielding plate.
    • Insert the tweezers.
  6. AirPods Charging Case Battery Replacement, Removing the docking tubes: шаг 6, изображение 1 из 2 AirPods Charging Case Battery Replacement, Removing the docking tubes: шаг 6, изображение 2 из 2
    • Wedge the special pry piece into the seam to pull out the docking tubes.
    • Please do not damage the flex cable while pulling out.
  7. AirPods Charging Case Battery Replacement, Optional - Opening case: шаг 7, изображение 1 из 3 AirPods Charging Case Battery Replacement, Optional - Opening case: шаг 7, изображение 2 из 3 AirPods Charging Case Battery Replacement, Optional - Opening case: шаг 7, изображение 3 из 3
    • If you still cannot open the case, you can build an extractor tool with two pieces of cable gland and two screws.
  8. AirPods Charging Case Battery Replacement, Remove the old battery: шаг 8, изображение 1 из 3 AirPods Charging Case Battery Replacement, Remove the old battery: шаг 8, изображение 2 из 3 AirPods Charging Case Battery Replacement, Remove the old battery: шаг 8, изображение 3 из 3
    • Attach the charging case to the holder and dip a small amount of alcohol on the battery.
    • Pry up the battery with the pry knife and the battery connector with tweezers.
    • Then take out the battery flex cable.
  9. AirPods Charging Case Battery Replacement, Test new battery: шаг 9, изображение 1 из 3 AirPods Charging Case Battery Replacement, Test new battery: шаг 9, изображение 2 из 3 AirPods Charging Case Battery Replacement, Test new battery: шаг 9, изображение 3 из 3
    • Take out the battery.
    • Using a multimeter is not required to successfully replace the battery.
    • Measured by the multimeter, the battery is found to have no voltage.
    • Get a new battery that has a stable voltage of 3.6v-4.0v.
  10. AirPods Charging Case Battery Replacement, Put in new battery: шаг 10, изображение 1 из 2 AirPods Charging Case Battery Replacement, Put in new battery: шаг 10, изображение 2 из 2
    • Attach the double-sided tape to the new battery.
    • Put the new battery into the charging case and connect the battery flex cable.
  11. AirPods Charging Case Battery Replacement, Test charging: шаг 11, изображение 1 из 2 AirPods Charging Case Battery Replacement, Test charging: шаг 11, изображение 2 из 2
    • Plug in the charging cable. The case should now charge normally once more.
    • Put the earbuds in. The earbuds should charge normally too.
  12. AirPods Charging Case Battery Replacement, Attach new battery: шаг 12, изображение 1 из 2 AirPods Charging Case Battery Replacement, Attach new battery: шаг 12, изображение 2 из 2
    • Peel off the double-sided tape and attach the battery to the case.
    • Install the docking tubes.
  13. AirPods Charging Case Battery Replacement, Test functionality: шаг 13, изображение 1 из 2 AirPods Charging Case Battery Replacement, Test functionality: шаг 13, изображение 2 из 2
    • Connect the AirPods to the phone. Both the charging case and AirPods can now be charged and used normally again.
Финишная прямая
12 человек успешно провели ремонт по этому руководству.
REWA
Участник с: 11/24/20
19 077 Репутация
Автор 55 руководств
4 Комментарии к руководству
Opening the case is the most difficult part, did it with two cheap pealing knives. And for inserting the cable you will need tweezers and this will be fiddly. Batteries are available from aliexpress and youre case will be as new.
San der - Ответить Поделиться
I feel like this guide could be a lot more descriptive and helpful, especially including tips on what to do and not do for each step, rather than assume we know exactly what you mean when you give each step in one sentence bearing half a dozen words or so. Also, there's absolutely no need to build a pair of pry tools, plastic picks work fine, and won't risk damaging either the case or the battery inside. Metal tools and lithium batteries are a no-no! Geez. With a pick wedged in the seam on each side of the case, like it shows in the picture, one final pick to the front seam can then safely pry out the holder from the case. Only the last pick will be used to pry, the other two just separate the inner case and outer case keeping the clips/catches unengaged, allowing for easy lifting/prying up and removal of the inner case.
Thousand Sunny - Ответить Поделиться
Are really sure that can use it plastic picks!?
Paolo - Поделиться
Great guideline. It helps me to replace the battery for my AirPods. Thank you.
Tony Lopez - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 27
За последние 7 дней: 219
За последние 30 дней: 1,005
За всё время: 56,442
