Alienware 17 R2 Keyboard Replacement
Выберете то, что вам нужно
  1. Alienware 17 R2 Keyboard Replacement, Close the Display: шаг 2, изображение 1 из 1
    • Close the display and turn the computer over.
    • Make sure PC is turned off!
  2. Alienware 17 R2 Keyboard Replacement, Loosen Screws: шаг 3, изображение 1 из 1
    • Loosen the captive screws that secure the base panel to the computer base.
  3. Alienware 17 R2 Keyboard Replacement, Releasing Tabs: шаг 4, изображение 1 из 1
    • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
  4. Alienware 17 R2 Keyboard Replacement, Remove Base Panel: шаг 5, изображение 1 из 1
    • Slide and remove the base panel from the computer base.
  5. Alienware 17 R2 Keyboard Replacement, Disconnect Battery Cable: шаг 6, изображение 1 из 1
    • Disconnect the Battery cable from the system board.
    • Turn the computer over.
    • Press and hold power button for 5 seconds to ground the system board.
  6. Alienware 17 R2 Keyboard Replacement, Battery Cable: шаг 9, изображение 1 из 1
    • Connect the battery cable to the system board.
  7. Alienware 17 R2 Keyboard Replacement, Tighten Screws: шаг 10, изображение 1 из 1
    • Tighten the captive screws that secure the base panel to the computer base.
    • WARNING : Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Make sure the base panel is removed.
    • Make sure palm rest is removed.
    • Lift the latches and disconnect the touch-pad cable and the status-light cable from the power-button board.
  8. Alienware 17 R2 Keyboard Replacement, Peel off the Cables: шаг 12, изображение 1 из 1
    • Note the touch-pad cable and status-light cable routing and peel off the cables from the keyboard bracket.
  9. Alienware 17 R2 Keyboard Replacement, Screw Removal: шаг 13, изображение 1 из 1
    • Remove the screws that secure the keyboard bracket to the palm-rest assembly.
    • Slide the keyboard cable, keyboard-backlight cable, macro-keys cable and macro-keys backlight cable through the slot on the keyboard bracket.
  10. Alienware 17 R2 Keyboard Replacement, Lifting the Keyboard Bracket: шаг 15, изображение 1 из 1
    • Lift the keyboard bracket off the palm-rest assembly.
  11. Alienware 17 R2 Keyboard Replacement: шаг 16, изображение 1 из 1
    • Remove the screws that secure the keyboard to the palm rest assembly.
  12. Alienware 17 R2 Keyboard Replacement, Releasing the Tabs: шаг 17, изображение 1 из 1
    • Release the tabs that secure the keyboard to the palm-rest assembly.
  13. Alienware 17 R2 Keyboard Replacement, Lifting the Keyboard: шаг 18, изображение 1 из 1
    • Slide and lift the keyboard along with the cables off the palm-rest assembly.
    • Slide the new keyboard under the tabs on the palm-rest assembly.
  14. Alienware 17 R2 Keyboard Replacement, Screw Alignment: шаг 20, изображение 1 из 1
    • Align the screw holes on the keyboard with the screw holes on the palm-rest assembly.
    • Replace the screws that secure the keyboard to the palm-rest assembly.
    • Route the keyboard cable, keyboard-backlight cable, marco-keys cable and marco-keys backlight cable through the slots on the keyboard bracket.
    • Align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
  15. Alienware 17 R2 Keyboard Replacement, Replace the Screws: шаг 24, изображение 1 из 1
    • Replace the screws that secure the keyboard bracket to the palm-rest assembly.
    • Adhere the touch-pad cable and status-light cable to the keyboard bracket.
    • Slide the touch-pad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
Заключение
Terrence15
Участник с: 12/18/17
79 121 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 985 руководств
Один комментарий
I find it concerning that this guide has you disconnect and reconnect the battery prior to doing anything with the keyboard.
Sean Hanson - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 10
За последние 30 дней: 21
За всё время: 2,014
