Введение
This guide will show you how to replace a broken optical drive. First you will need to remove the back cover then the battery in-order to get to the optical drive.
Выберете то, что вам нужно
Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
Using PH1 screwdriver loosen the two screws on the right of the battery.
Unscrew the four 6.35mm screws using the PH1, that hold down the optical drive.
Using the plastic opening tool unclip the white connector holding down the orange cable.
Using the tab on the optical drive, lift the optical drive out of the computer and set it aside.
