Alldaymall A88X Battery Replacement
Выберете то, что вам нужно
  1. Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: шаг 1, изображение 1 из 3 Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: шаг 1, изображение 2 из 3 Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: шаг 1, изображение 3 из 3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X Battery Replacement: шаг 2, изображение 1 из 1
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X Battery Replacement, Battery: шаг 3, изображение 1 из 3 Alldaymall A88X Battery Replacement, Battery: шаг 3, изображение 2 из 3 Alldaymall A88X Battery Replacement, Battery: шаг 3, изображение 3 из 3
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to server any of these.
  4. Alldaymall A88X Battery Replacement: шаг 4, изображение 1 из 3 Alldaymall A88X Battery Replacement: шаг 4, изображение 2 из 3 Alldaymall A88X Battery Replacement: шаг 4, изображение 3 из 3
    • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
    • After the battery is separated from the panel make sure to place it face down above the tablet itself.
    • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
  5. Alldaymall A88X Battery Replacement: шаг 5, изображение 1 из 2 Alldaymall A88X Battery Replacement: шаг 5, изображение 2 из 2
    • Desolder the wires that connect the battery to the motherboard.
Заключение
4 участников успешно повторили данное руководство.
Alex
Участник с: 02/10/16
101 Репутация
1 руководство автора
Команда
USF Tampa, Team 4-1, Lacy Spring 2016 Участник USF Tampa, Team 4-1, Lacy Spring 2016
USFT-LACY-S16S4G1
4 членов
Автор 16 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 1,108
