Alldaymall A88X Speaker Replacement
Выберете то, что вам нужно
  1. Alldaymall A88X Speaker Replacement, Alldaymall A88X Back Cover: шаг 1, изображение 1 из 3 Alldaymall A88X Speaker Replacement, Alldaymall A88X Back Cover: шаг 1, изображение 2 из 3 Alldaymall A88X Speaker Replacement, Alldaymall A88X Back Cover: шаг 1, изображение 3 из 3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X Speaker Replacement: шаг 2, изображение 1 из 1
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X Speaker Replacement, Speaker: шаг 3, изображение 1 из 3 Alldaymall A88X Speaker Replacement, Speaker: шаг 3, изображение 2 из 3 Alldaymall A88X Speaker Replacement, Speaker: шаг 3, изображение 3 из 3
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to sever any of these.
  4. Alldaymall A88X Speaker Replacement: шаг 4, изображение 1 из 3 Alldaymall A88X Speaker Replacement: шаг 4, изображение 2 из 3 Alldaymall A88X Speaker Replacement: шаг 4, изображение 3 из 3
    • Using a pair of tweezers, begin separating the tape downwards from the back panel.
    • Pull the tape away from the wire bundle beneath.
    • Isolate the wire running from the speaker to the motherboard.
  5. Alldaymall A88X Speaker Replacement: шаг 5, изображение 1 из 3 Alldaymall A88X Speaker Replacement: шаг 5, изображение 2 из 3 Alldaymall A88X Speaker Replacement: шаг 5, изображение 3 из 3
    • Desolder the speaker wires from the motherboard.
Заключение
Drhaber
Участник с: 02/10/16
985 Репутация
Автор 7 руководств
Команда
USF Tampa, Team 4-1, Lacy Spring 2016 Участник USF Tampa, Team 4-1, Lacy Spring 2016
USFT-LACY-S16S4G1
4 членов
Автор 16 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 222
