Введение
The Amazon Echo Look's primary function as a fashion assistance can be affected if the front panel is cracked or if the lens is smudged on the inside or otherwise damaged.
Some steps are time-sensitive and may need to be repeated- the time estimate reflects this.
Выберете то, что вам нужно
Ensure the device is completely powered off and disconnected from any power source by removing the charger adapter point from the back of the device.
If the device stand is attached, remove it by twisting the device's base toward yourself until detached.
Heat the front panel with an iOpener.
Heat the device for 5-10 minutes to loosen the glue.
Lever the Jimmy between the screen and the device until an opening is formed.
Insert opening picks to hold the opening as needed.
Use a spudger to circle the border of the front panel and disconnect any lingering glue.
Еще один человек закончил это руководство.
